FWC
Apr 11, 2021Explorer
If you don't understand energy, 50% more usable Ah would suffice.
You are right that the capacity is the same at the 20hr rate. But my understanding was that your requirement was to support high inverter load for longer before your inverter shut down. In which case a dual purpose AGM would be both cheaper and be able to support your high current loads for longer run times before the inverter alarms.
As shown above, a lithium would have performed much better than either lead acid batteries.
