BFL13
Apr 18, 2021Explorer II
FWC wrote:
You would want to enter 120Ah for your 120Ah battery, as it states clearly in the spec sheet.
FWC, the spec sheet says 120AH "nominal" It gives the capacity as 1536 Wh without saying, "nominal". It says the 12.8v is "nominal". So why do you believe the "real" capacity is 120AH? If it is, then the Wh figure is wrong AFAIK. (13.6 is full, not 12.8)
Do you believe or know that they measured its capacity as 120AH first, then derived that 1536 Wh figure afterwards from the nominal 12.8 voltage?
If so, how do you think they got that 120AH? By running it at 120a for 1 hour? Or how? The usual 20 hr rate test ends at 10.5a but these batts are "depleted" at 10a. Not sure that works.
Be very interested in your explanation, thanks.
