pianotuna's avatar
pianotuna
Nomad III
May 20, 2019
li batteries--a good primer
Hi all,
This is a good explanation of what to expect from LIfePo4.
https://www.solacity.com/how-to-keep-lifepo4-lithium-ion-batteries-happy/
Here is their summation:
To sum up, for long and happy LFP battery life, in order of importance, you should be mindful of the following:
Keep the battery temperature under 45 Centigrade (under 30C if possible) – This is by far the most important!!
Keep charge and discharge currents under 0.5C (0.2C preferred)
Keep battery temperature above 0 Centigrade when discharging if possible – This, and everything below, is nowhere near as important as the first two
Do not cycle below 10% – 15% SOC unless you really need to
Do not float the battery at 100% SOC if possible
Do not charge to 100% SOC if you do not need it
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
