crewcabfor2
Feb 23, 2018Explorer
Sorry it took so long to get back,here is what i did and the results.I did get the board removed but could not see any hot spots or discoloration,what i could not see was covered up with epoxy.i unplugged every connection and re installed them. No difference.I then went and did the same to the connect panel no difference. I started up the gen. and started to move the wires behind the panel all of a sudden the red light went off,connection maybe? and it seemed to be at the oil,run and overload relay? but can not verify. I restarted gen. light came back on,then i got this idea i switched the high idle switch on and then started it,light came on flashed a couple of times and went off,restarted on economy setting ,light flashed once and went off and did the same every time i started it over a week. Fixed? i do not know but happy it seems to be okay.I just want to thank all the people that helped me. Tom
