smokeylew's avatar
smokeylew
Lifeline AGM bank of four w/ 2 older than the new ones
Have two 14 month old Lifeline AGM 6v batteries I pulled from my older TT and purchased two more of same to build a bank of four for newer 5th wheel. Older batteries have been well maintained scence originally installed. Connected in series/parallel for 12v and use two 100 watt solar panels for charging.
You think mixing ages will be a problem for this setup? Very expensive to buy two more new ones to match ages of new ones.
Thanks for responding.
  • Do
    Not
    Recharge
    AGM
    Batteries
    With
    Less
    Than
    20% amp hour capacity recharge amperage
    If the battery has been discharged more than 60% remaining capacity.
    i.e. 200 ampere hours bank capacity. Equals 40 ampere MINIMUM recharge rate.
    There is a time constant which seems to kick off after say 10 days of sub minimum recharge. Weekend warriors need not worry. Long-term off-grid, worry.
  • How many total amps will you have? Will you have enough solar?
    Typical 4x6 volt = 400+ amps
    1 watt per amp rule of thumb.
  • Good suggestions guys. I can always count on great feedback from you all
  • Why not prove it to yourself? Charge fully then disconnect all 4. The following morning take voltage readings across each battery. What do you see ? :)
  • I agree. If you still have some concerns, I'd give Lifeline a call and talk to one of their technical experts. I had an issue with a bank of 6 new lifelines and after talking to one of their engineers, I got a ton of great information on my issue and the problem I had been having as well as getting my problem solved. If you talk to them, ask them how to set up your battery bank mix. Do you put the 2 new in series together, or do you split the bank with a new and old each in their own series. I don't know if it would make a difference, but it's worth the question to an expert.
  • time2roll wrote:
    14 months and well cared for? I would combine with the new and not worry one bit.
    x2
    Lifelines are very good quality, and at 14 months I think you'll be fine. Make sure all 4 are FULLY charged before connecting up. You should also monitor individual voltages to ensure things are staying in balance. Both sitting and under load.
    I just yanked a set 8 4-yo 12 volters from my coach, and they're all sitting at around 12.8 with very little variation.
  • 14 months and well cared for? I would combine with the new and not worry one bit.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
