pianotuna
Nov 13, 2021Nomad III
Teleman,
That is a good decision. Can it be limited to 20 amps if need be? It is a far superior make.
Another reason to have a bypass circuit is for a "poor mans" boost switch. If the chassis batteries are dead, you would be able to get some amps into them from the "house" bank. Don't have it "active" when starting. The Li bms will NOT like it.
If the alternator did fail, then that bypass circuit could be used to keep the engine running a lot longer while getting to a service center. Of course the Redarc ought to be turned off to do this.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
