mdkelley's avatar
mdkelley
lifepo4 and maxxfan
Hello,
I am new here. I didn't see a new member introduction so I will do that quickly before posting my question.
Matt from Michigan. I have a 1989 pop top 8' skamper on a 2004 2500 duramax. So far I have installed a MaxxAir fan, one LiFePO4 battleborn with a power dynamics Li single stage converter/charger, and removed the non-functioning 3 way fridge and am putting a 5000btu AC unit in that space. I also purchased a 2200 honda generator to use for off-grid battery charging and running the tiny AC unit. This camper follows a van conversion camper the wife and I used for about 4 years. Also installing a WiFi ranger and have a wilson cell booster. That pretty much rounds out my rig introduction.
My question: Will my power dynamics 45 amp LiFePO4 controller burn out my MaxxAir fan? I ask because I think it did! So, on to question2. If that is true (too much voltage to run a fan) what regulator do other use to get around this issue? I wired the converter in to my system to act as shore power and have a quick disconnect to put the battery into the system when not on shore power or if I need to charge the battery. I figured there is no reason to constantly charge the battery if I am on shore power. I am not sure if I need to get a 12v regulator that is rated at 45 or more amps since that is the output of the converter, or if the regulator's amperage rating is more for amp draw and not really an amp input rating. I would think maybe a regulator from a truck may work since an alternator usually puts out more than 45 amps but looking for some guidance from someone who has done this already so I can avoid any implementation headaches (learning curve).
Thanks,
Matt Kelley
Michigan
Having RV issues? Connect with others who have been in your shoes.24,326 PostsLatest Activity: Oct 23, 2025
