phemens
Jul 22, 2019Explorer
Itinerant1 wrote:
phemens did you get the soc % figured out between the bmv-702 monitor & the batteries display, you mentioned that in the other thread?
I spoke with Victron, Samlex and the battery mfg. The BMV-702 is accurate for amps out, pretty much every other reading I figure is useless (SOC on BMS I was informed is not extremely accurate, the BMS uses voltage only for protection). So now I will use only the 702, and get over my inherent paranoia over SOC ;)
