Itinerant1
Jul 24, 2019Explorer
Mine are not dropin but GBS Elite power solution prismatic cells. Which have these connected between the 20 cells that connect to the CPU/ EMS...
When a sense board is installed correctly the green led will light up. There is also a red LED on the sense board, which indicates cell balancing is occurring. This led will light up any time the cell voltage is 3.55V or higher.
Note: not by a certain battery voltage but by a cell voltage. Yes some cells climb faster in voltage than others.
From reading different manufacturers and surfing different forums most "suggest" 14.4-14.6 for both the resetting of the SoC % capacity and to balance the cells.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
