time2roll wrote:
BFL13 wrote:
You need 14.x to get those ions moving better. Once there you can lower the voltage
Lower charging voltage than 14.6 needs more time so keep
Float voltage same as Bulk longer too till desired SOC is reached
I respectfully disagree.
I got that from the Solacity guy.
https://www.solacity.com/how-to-keep-lifepo4-lithium-ion-batteries-happy/"So what Voltage is enough to get those ions moving? A little experimenting shows that 13.6 Volt (3.4V per cell) is the cut-off point; below that very little happens, while above that the battery will get at least 95% full given enough time. At 14.0 Volt (3.5V per cell) the battery easily charges up to 95+ percent with a few hours absorb time and for all intents and purposes there is little difference in charging between 14.0 or higher Voltages, things just happen a little faster at 14.2 Volt and above."
He says longer "absorption time" which to me means after the battery reaches the set high voltage of the charger (controller for solar) so not sure that he means amps also taper for longer starting from a lower SOC like happens with fast charging a FLA.
On that, he has the LFP fast charging at 50% rate getting to 90% before amps taper, then says using the lower charging rate of 14 vs 14.6 means it gets to 95% before amps taper so that is kind of like FLA but not clear to me it is from the same battery chemistry internal whatever goings on.
EDIT--he had the 90 vs 95 when using the high charging rate as well as 14.6, so not clear that you do go higher in SOC before amps taper just from using a lower charging voltage (at what charging rate?)--but how can absorb time be longer and also get to a higher SOC before tapering Can't be both.
With a "few hours absorb time" I assume the usual notion that you only need ten or twenty minutes for LFPs does not apply at those lower than 14.6v charging rates.
With the longer absorb time I tacked on the idea in the Garage post earlier to keep Float at Bulk for longer too
ISTR Battle Born says voltage has to be 14.2 or so to even be able to balance their LFPs, but if you are not planning to do that, a lower charging voltage won't matter for I suppose.
time2roll always preferred slower charging for FLAs too
