BFL13
Mar 29, 2021Explorer II
You will be able to run down to 20% SOC without hitting the inverter alarm at 11v, but that does not mean you get to use 160AH out of the 200 for running time at 100 amps.
The higher discharge rate means a shorter running time down to "end voltage" so not as much H in the AH.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
