jaycocreek
Oct 26, 2021Explorer II
What is the correct resting lifepo4 voltage?
I bought a Enjoybot 100ah lifepo4 battery when they were $349..The resting voltage after 24hrs was 13.30 without a load..Back and forth with the seller was interesting,so I decided to do a capacity test on it from a full 14.47V and I quit at 11.89V under a load and 12.0 resting for a few minutes foran even 100 amp hours...
I am assuming that a 13.30 resting 24hr voltage without a load is okay as it appears to have the advertised 100 amp hours plus a couple...All opinions welcome...
Resting after a couple minutes at 100 amp hours.
Under load when I hit 100 amp hours..
I had to raise the amp hours to 102 in the settings to get the % closer..
