otrfun
Oct 27, 2021Explorer II
We've done a number of deep discharge SOC tests with our 200ah lifepo4. Found the following chart reasonably accurate as long as there is no dynamic charge voltage or load voltage sag present. BTW, this chart contains the same voltage/SOC data as the BB chart in BFL13's link.
Note, there's two voltage readings (13.6v and 14.4v) that reference 100% SOC in this chart. We found this to be true when the converter is on (in 13.6v absorption and/or 14.4v bulk mode), *and* little (<.1a) to no charge current is flowing.
This chart and personal testing has confirmed our decision to keep our 3-stage (13.2v/13.6v/14.4v) lead cell converter to charge our lifepo4 (vs. using a lithium/lifepo4 1-2 stage 14.6v converter). Zero chance of overcharging, plus for all practical purposes we're still able to charge our lifepo4 to 100%.
I might add we did try charging our lifepo4 with our our dc to dc charger at 14.6v (vs. 14.4v) several times. Discovered it provided no noticeable difference in available ah (or SOC), vs. charging at 14.4v.
Having RV issues? Connect with others who have been in your shoes.24,276 PostsLatest Activity: Jun 26, 2025
