FWC
Mar 29, 2021Explorer
Sounds like Aims may use a lower resistance BMS, which is a plus.
If it is a problem, another option would be to lower the inverter alarm point, or turn it off completely. The BMS will save you if you run things down too far.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Mar 09, 2026
