FWC
Mar 31, 2021Explorer
jaycocreek wrote:
Will Prowse says you can tell the state of charge for a Lifepo4 battery,or get a good idea without a load..He is talking about the Battleborn..
Will Prowse on SOC lifepo4
He seems just to be regurgitating the stuff from Battleborn. I have no idea why people seem to think this guy is some sort of expert.
Anyway, this should highlight the issue of trying to determine SOC from voltage:
This is the voltage of several different cells at 80 and 90% SOC vs temperature. First notice the difference is at most 0.004V, and that the curves cross as a function of temperature, so depending on the battery temperature 80% SOC may actually have a higher voltage than 90% SOC. At best you may be able to tell if a battery is full or mostly flat, but not much more than that.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
