StirCrazy
Apr 01, 2021Moderator
BFL13 wrote:
If you did have BMS cut-off, don't forget you will need a way to get the battery bank going again by recharging it. BB suggests you have a charger that can do that. EG my Vector smart charger will not do anything until the battery voltage is above about 5 volts, so it would not work on a cut-off LFP.
wow, man is it good thing we have chargers built into our RV's or we would be totaly screwed..
actualy it would because a BMS cutoff point is above 5V, if I was setting up my own it would cut off at 11.9 but even if you have it cut off at 10.1V that is still above 5V.
Steve
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
