StirCrazy
Apr 01, 2021Moderator
FWC wrote:jaycocreek wrote:
Will Prowse says you can tell the state of charge for a Lifepo4 battery,or get a good idea without a load..He is talking about the Battleborn..
Will Prowse on SOC lifepo4
He seems just to be regurgitating the stuff from Battleborn. I have no idea why people seem to think this guy is some sort of expert.
Anyway, this should highlight the issue of trying to determine SOC from voltage:
This is the voltage of several different cells at 80 and 90% SOC vs temperature. First notice the difference is at most 0.004V, and that the curves cross as a function of temperature, so depending on the battery temperature 80% SOC may actually have a higher voltage than 90% SOC. At best you may be able to tell if a battery is full or mostly flat, but not much more than that.
I dont think he is any sort of expert, he is just curious with youthfull exubrance and a little goofy. he also seems to have access to a lot of stuff to test.
but yes on a static LFP you can get a very reasonable measurment of soc from voltage in a percentage of capacity, once you put a load on it thats out the window and you need predictive coulumb counting (did I butcher that?) I have ecen seen a couple meters that claim "advanced predictive coulumb counting" havent read of to see what the difference is yet but its suposed to be even more accurate.
Steve
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 25, 2026
