pianotuna
Apr 01, 2021Nomad III
jaycocreek wrote:FWC wrote:
The Victron smart shunt WILL determine SOC accurately as it is not based on voltage, it is based on counting the current in and out of the battery.
But to be clear it does not completely replace the functionality of a bluetooth enabled BMS. While it will give you SOC, it does not give you individual cell voltages (to check balance), internal temperatures or the ability to adjust any of the BMS settings.
Thank you
You do have to set the capacity. As I've said before capacity is a moveable feast. So as good as the smart shunt is--it is not determine the SOC accurately even though it does count the amp-hours used. It is a useful piece of kit to own.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
