StirCrazy
Apr 02, 2021Moderator
BFL13 wrote:
After BMS cut-off you can charge the batt and eventually it will come back on. Until it comes back on you have no 12v in the RV from that batt.
If you have an inverter/charger, which needs 12v to even be on so you can use its charger, how are you going to use the inverter/charger? It is dead.
You can use your converter as long as you have a gen to run it with. The converter can also then supply 12v to the RV while you wait for the battery to come back to life.
If your installed gen needs that batt to start it, your gen can't be used to run the converter. A portable gen would start.
Solar could be used unless this happens at night.
So you need a way to deal with it in your RV. Too late if it happens and you never thought of that.
this isnt a problem spicific to LFP, you run any battery dead and you need a way to charge it. I think part of building a battery no matter what the type is insuring you have enough capacity to do what you do. if not then you have to ensure you have a way to charge it.
Steve
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
