BFL13
Apr 02, 2021Explorer II
Thanks for the long report! (I added your original post to my question while you were posting that)
So the inverter/ charger had lights at that point, so it did have 12v then, but not known where it stood during the "no 12v" time? It was off as shown by having the OEM settings afterwards?
Just curious--can you get 12v to the rig via 7-pin with your set-up if the trailer batts are 'dead in the water' for any reason? Will that light up the Magnum?
-With the trailer batts ok, do you mind paralleling the truck battery with the LFPs via 7-pin? I worry about mixing battery types, but I am told here that is not an issue really. What do you do? Thanks.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
