StirCrazy
Jun 02, 2022Moderator
pianotuna wrote:
CA Traveler,
Do those other charts show voltage under load? All the ones I found seemed to just be resting voltage based.
the one looks like voltage at a spicif capacity, the second is just a time as a spicif discharge , nether is voltage under load as it would generaly be a pretty complacated chart and I don't know if I have even seen one for a regular battery.
LFP have lower internal resistance and close to no Pukert (speling that wrong probably but on my way to work soon) so the voltage drop under load vs resting will be close to nothing. I have heard and seen videos of people running inverters and such on 100amp banks to 10% capacity with out triggering the alarm on the inverter so that should tell you something but now you have my curiosity peaked so I'll see if I can find anything.
Steve
