- jaycocreekExplorer II
2oldman wrote:
JKJavelin wrote:
You won't know until a couple years later.
Still, a lithium battery with a BMS for under $300. Too good to be true?
Or you can pick one of the batteries Will P has torn down and compared that are in that price range..Other than the cold cut off,Will has recommended or commented that Ampere Time/Chins and Zooms are identical batteries internally except for the name on the case..Same BMS/cells and quality connections etc inside...
I think the Chins and Zooms are both under $320 last time I looked...
Jayco - 2oldmanExplorer II
Still, a lithium battery with a BMS for under $300. Too good to be true? - JKJavelinExplorer III
time2roll wrote:
OK to delete the tracking, marketing referral and search data after the item number...
https://www.amazon.com/Lithium-LiFePO4-Battery-Perfect-Trolling/dp/B09N6Q9ML9
Wow!
This company is Energy Lions.
Easy to confuse with the more established Lion Energy. Even the lion head emblem is similar.
Still, a lithium battery with a BMS for under $300. Too good to be true? - jaycocreekExplorer II
3 tons wrote:
Returning to the topic, a quick re-check at amazon, dropping prices suggest that for some folks FLA’s might soon be getting kinda hard to justify - though I cannot personally attest to amazon’s LFP offerings…
3 tons
I tried one of there sub $350 100ah lifepo4 batteries and got 104ah out of it...it seems to have a weird voltage curve but in the end,it delivers what was promised..I'm quite happy with it and have been using it 24/7 with a compressor fridge..
It seems these new lifepo4 battery makers have little price wars on Amazon which is a good Time to make the leap if so inclined.. IMHO...
Jayco - 3_tonsExplorer III
Many thanks :)
3 tons - OK to delete the tracking, marketing referral and search data after the item number...
https://www.amazon.com/Lithium-LiFePO4-Battery-Perfect-Trolling/dp/B09N6Q9ML9 - Itinerant1ExplorerWow, they almost look like Lion Energy batteries. I wonder if the price is to good to be true.
- fj12ryderExplorer III
Grit dog wrote:
Well, it you're bothered by what bothers us, "trust me when I say that the problem is not him. It’s you." :)fj12ryder wrote:
2oldman wrote:
I usually decide they aren't worth the effort and pass them by. Life's too short.
Posts with constant misspellings are distracting. Can't you find a spell-checker off line and compose there first? Facebook has it and likely your email.
If you two literally are bothered by this, trust me when I say that the problem is not him. It’s you. - 3_tonsExplorer IIIReturning to the topic, a quick re-check at amazon, dropping prices suggest that for some folks FLA’s might soon be getting kinda hard to justify - though I cannot personally attest to amazon’s LFP offerings…
3 tons - Grit_dogNavigator II
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 20, 2025
