toban
Mar 13, 2015Explorer
Light in a singled door NDR 1062 Dometic Fridge
I thought the light had burnt out. It turned out the plunger the door pushes in to shut the light off when the door is closed is acting up. When the door is open the light does not come on but if I push the plunger in and out a few times the light comes on. It would seem the switch inside the plunger mechanism in the housing which is attached to the top of the inside of the fridge is acting up.
Is there a way of taking this off and lubricating the switch? It is attached to the inside roof of the fridge by some plastic tabs.
Hopefully I have been clear on my description. Thanks.
Toban
Toban
