Roger10378
Mar 28, 2015Explorer II
A LED would be a good idea as I am sure the switch burned up due to the amount of current being switched on and off frequently. However the light bulb is also used as the heat source when you turn on the low ambient switch so a LED would eliminate that feature.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 14, 2026
