- MEXICOWANDERERExplorerAbsolutely no experience...
Are furnace blower motors permanent magnet style? - tpiExplorer
- mena661ExplorerOff topic but where did you get the 4G amp from?
- tpiExplorerI have 300 amp hour AGM batteries, 200W panel. 24' class C.
LED lights.
3.5 amp furnace
1 amp @ 12V Macbook Air laptop used extensively
19" LCD TV not used extensively, if it was I'd switch to more efficient LED TV.
Various small chargers, 4G amplifier, etc.
Fantastic Fans as needed.
No attempt to use 12 volt power to heat anything such as water, food, etc.
For my use, three or four days here or there, it is plenty. It would be plenty for a week in typical camping temperatures. The more I'm out of the RV exploring, socializing etc, the less power I consume. If it comes home with a battery deficit a day or two parked in the sun takes care of it. - vermilyeExplorerWhile having a fairly small trailer provides an advantage, I can dry camp until I fill the tanks (the longest so far has been 2 weeks). I have all LED lighting, a furnace that only draws 1.8 amps, a pair of 6V, 225 amp/hr batteries, and a 95 Watt solar panel with a PWM controller.
Additional loads include making a pot of coffee each morning using a 5 cup, 600 watt coffee maker, a couple of hours per day on a computer that draws as much as 9 amps @ 12V, a 3 watt Cell amplifier & WiFi Ranger router, and a bunch of misc battery chargers. I don't carry a generator. - mena661ExplorerI had all LEDs in my "old" 5er. HUGE difference in power draw.
- doughereExplorerI'd rearrange order:
LEDs
2 6V GC batteries
Solar Panel and controller
2 Group 27's have about same AH capicity as 2 GC's, GC's seem to be better designed for RV's; certainly either will serve you well.
We have all LED lighting, 2 GC's, 2KW gen, just added 220 watts solar. Presently we can go 4-6 days (not needing heat) between charging. Hoping with solar to essentially eliminate having to run generator. Kinda wish I had gotten solar before gen; may well have not needed it (at least handy if we loose power during storms).
Regards,
Doug - handye9Explorer IIMy set up is two group 24, two 128 watt (24volt) panels, MPPT controller, and LED lights.
- hmknightncExplorerThat's basically what I have. 265watt solar with PWM controller and 2 GC2 six volt batteries. Works great for long weekend dry camping
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
