Davidlee64
May 03, 2017Explorer
Lighting Partial No Power
I purchased a 36' Sportsmen Sportster 5th wheel trailer 21 Apr 17. I am occupying it full time, and fixing little things as I go. I replaced the cabin lights with LED's and all work except the 2 fixtures in the slide. I have been tracing the wires trying to find where the power stops. I have 12V up to where the coiled wires attach to the slide. I did a continuity check and found the white wire is good, and the bl/w wire shows no continuity to the fixture. That explains the lack of 12V. I pulled on the wires to attempt to run new wires, but they won't budge. It looks like the only option is to pull the paneling to expose the wires. I don't see how the paneling is attached. Might anyone have some insight as to how I can replace the pair of wires, or access them to repair? I would really like to be able to use the lights.
