cannesdo
Dec 18, 2016Explorer
enblethen wrote:
You have a DSI (direct spark ignition) water heater. There is no pilot!
You can light some with lighter as you tried. But that is not the correct way.
You need to check the adjustment on the flame sensor/ignitor.
Then clean the contacts on the circuit board.
Check the ground on the electric gas valve.
Check the two coils on the gas valve with Ohm meter readings should be the same.
Suburban owners manual
Where is the circuit board?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
