westend
Dec 19, 2016Explorer
enblethen wrote:Or, through a user if he is well grounded.;)
The red ignition wire is grounded through the ignitor when it arcs.
The best thing you can do for your water heater, if it hasn't been used with LP for years, is to disassemble the final operating bits and clean it thoroughly. This involves the gas delivery tube, the orifice, and the igniter. I would suggest to NOT remove the gas valve's delivery piping. If your range and furnace are operating, the last bit of gas piping will be filled with LP and displace the air within a few ignition cycles.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
