SoundGuy
Aug 08, 2017Explorer
RobWNY wrote:
We are camping in a place where we can receive 18 over the air television stations using our Antenna and booster that came installed on our camper. If we don't use the booster, we get nothing.
Of course you won't get anything as that wall plate is NOT a booster, has no ability at all to amplify (or boost) the signal. Rather, all that wall plate does is route 12 vdc to the antenna head where there is a signal amplifier that boosts the strength of the received signal. You may lose the signal when turning on a light if it's an LED bulb that in effect radiates an interfering signal - if this is a concern then switch to LED bulbs that don't.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
