Trixie47's avatar
Trixie47
Lights dimming
We have a 2012 Avalanche...lights were very dim so figured it was the inverter/converter, so took it in to Camping World....they said the converter was good needed new batteries. Bought two new batteries a few weeks ago. Getting ready for trip and now lights are dim again and frig lights are now blinking on and off. We have been hooked to shore power here at home. Anyone have any idea what we could look for ?
Thanks so much....
  • The simplest things can be so difficult sometimes.
    You are looking for 13.2 volts on the battery. Then disconnect the battery and check for voltage in the RV. Then check the main converter fuses. Bench test the converter. Install new converter.
    If you charge from a generator make sure the replacement is a Progressive Dynamics or IOTA.
  • turn off shore power
    start checking battery cables,
    look at the negative cable where is bolts to the frame
    then open the cover on the converter and check all the wiring connections
    also this is TT ? right ?
    so follow the positive battery cable from the batteries, find the DC thermal circuit breaker
    looks like a silver box with (2) wires attached
    common size is 40amps, replace it
    temporary test is unbolt the wires and bolt them together, if power is OK, the thermal breaker is bad
  • The lights work off the battery(s) so I would check the voltage there. It should be around 12.6 volts when not charging. Were the new batteries charged up with proper water level?
  • Sounds like CW might have sold you something you really didn't need. Easier to take your good money than to find the problem. Apparently the batteries weren't it.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 14, 2026
