brulaz
May 27, 2016Explorer
fj12ryder wrote:
TucsonJim, those look like the wrong shackles as they appear too thin. I got the wetbolt kit from Dexter and the shackles were much thicker than what you're showing. Mine came with the same type of locknuts and they worked fine because they butted up against the shackles. I would not use those shackles as they are not correct. When the bolts are tightened down the shackles should become a solid unit, with no movement by the shackles.
In your other picture where you say that the locknut doesn't make contact with the shoulder of the bolt, it won't when the bolts are installed properly. The shackles will be what the shoulder of the bolt contacts. Or the bolt shoulder will contact the inside of the hangers and the nut will lock down on the hanger.
Do not use those parts on your trailer, it's not correct and you could end up with some serious damage.
Agree, those shackles look way too wimpy.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
