fj12ryder
May 27, 2016Explorer III
When you bolt those shackles together they should be solid, you should not be able to move the shackles separately. They should not be able to be rotated on the bolt. They shouldn't rattle. If they aren't solid something is way wrong.
Edit:
On edit, I've done some researching and your parts are probably the correct ones, but they are seriously deficient in design. I have explained my erroneous advice in my post near the end of this thread.
Sorry for the somewhat misinformation. Personally I would use the parts you have, not because they're wrong, but because the way it is "designed" to work is ridiculous.
Edit:
