randallb
May 27, 2016Explorer
This is a case of DIYDDIYD. When the use of "wet bolts" and bronze bushings was common nobody bothered to grease them and then complained of squeaking and binding. Nylon bushings do away with the squeaking complaint but have a higher wear rate. Have you ever seen the inside of a trailer that has binding or seized spring bushings. It is not pretty.
Randy
Randy
