fj12ryder
May 28, 2016Explorer III
mlts22 wrote:Shouldn't need it, and if it does then something is wrong. The nut should pull up tight against the surface, that's how it's designed.
Wonder if some LocTite Blue on that one nut that is knurled would help with anti-torquing, or perhaps adding a second jam nut?
Edit:
On edit, I've done some researching and your parts are probably the correct ones, but they are seriously deficient in design. I have explained my erroneous advice in my post near the end of this thread.
Sorry for the somewhat misinformation. Personally I would use the parts you have, not because they're wrong, but because the way it is "designed" to work is ridiculous.
