dougrainer
Jul 28, 2014Nomad
taylorg wrote:
Does anybody know where I can locate a diagram/schematic for the Lippert electric landing gear system for an rv. I am diagnosing why the gear drive and motor wobble and bind up when it is being lowered or raised.
If you are talking about the STABILIZER LCI system, wiring would have no bearing on your problem. The problem is mechanical. Same if you are talking about the front Hitch electric tongue jack. Motor Wobble on LCI stabilizers is normal, Binding is NOT unless you overloaded the stabilizers and bent the stabilizer arms/frame. These are stabilizers, NOT levelers. If you try to use them to level the trailer you will bend them. Doug
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
