Kayli_s_Papa
Apr 09, 2017Explorer
Thank you for the information.
Were all these installed systems OEM or aftermarket? Are the brackets fot the rear and (if installed) middle legs welded or bolted on the frame? Your thoughts on the bolted bracket vs the welded brackets. My trailer is 39' 11" ( per tech. specs) and GVWR of 15,950 # So research has indicated that I will need to install a 6 point system due to spacing between the front legs and the rear wheel location.
I am so looking forward to having the trailer not rock when we are set up. This will make my bride of 46 years estatic and as well all know happy wife/happy life.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
