02rexhall's avatar
02rexhall
lippert jack rebuild
I have one of the jacks leaking fluid on my Lippert level up system. Does anyone know if they can be rebuilt or must it be totally replaced.
Is this a do it yourself project,if so anything I should know before starting this repair?
  • just read where this company rebuilds the Lippert units
    http://www.robertsqualityrv.com/
  • I contacted Lippert a couple years ago and was told there is no repair kit for the Lippert cylinder, if I were you I would take it down to a hydraulic shop and they should be able to get the parts and rebuild it for you, this topic has been discussed before but know one that I know of has never reported back to the results, you may want to also check and be sure that the lines going into the top of the cylinder are not leaking, I have one at the moment that is seeping a little that needs tightening as others have had the same issue...
