minimutt's avatar
minimutt
Lippert leveling problems
We are setup permantly in Fl & are Snowbirds. When we try to turn on the leveling nothing happens. Are there 2 AA batteries in back of switch? Please help. Thank you.
NOTE: Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions on how to post in the forums, signature and photo testing, reporting website or member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, create future threads in the RV FORUM which corresponds to the subject of your topic. Thank-you!"
  • We called LCI & was told no batteries are required for backside of control. They helped us & got it working. Think there was a lose wire. Thank you.
  • Stating you have the LCI leveling system is like stating you have a Ford and you have a problem with your car. Kind of hard to help with no specific info. LCI makes a lot of leveling systems. So, it appears you also have a 6 year old RV. Stating what MODEL of LCI will help us get you help. There are NO LCI leveling system that I am aware of that use any type replaceable small batteries. For the remote, Maybe. IF you have the handheld remote that is optional on some LCI systems. But, with or without a remote there is still the standard wall pad that will activate the leveling system. Is this RV new to you or have you never operated the Leveling system? Doug
  • We do have papers on it but very confusing. One says there are 2 AA batteries on back side but doesn’t look like ours.
  • Far as I know, all the leveling is tied into the 12 volt battery system. Perhaps check the fuse. Does your Montana not have literature on the leveling system? You could also do a Google search for the type of system you have and troubleshoot from there.
  • We have the Lippert leveling system on our 2013 Montana.
  • Slippery makes many types of systems. It would help to know what kind you have.
