dougrainer
Jul 03, 2021Nomad
WHY are you looking for it? The LCI system is complicated and when a novice fools with it, it makes it harder for whatever problem you had harder to fix. But, usually on your floorplan it would be located up front under the front bed in the outside storage behind a false wall panel. Doug
