caryncbreeef's avatar
caryncbreeef
Liquid Rubber Roof or new EPDM Roll roofing?
Hello everyone, haven't posted in a while - Have a 2000 Coachman Santara 31'. 1st off I am disabled but my wife is not. We found a leak in the cabover and fairly bad rot in the slide in bed area above the driver /passenger seat. that can be handled with different 2 part epoxies - we have been told to seal the side walls to the curved front cabover with a high end boat epoxy. but it is time for a new roof - I cannot afford the high end bedliner type which is $4k and up - or to have a shop do it - also $3700+ . Did much research and between the EPDM Liquid Rubber Roof - probably about $6-$700 or a 60 mil EPDM white roll roofing about $7-$900.
Has anyone had the liquid rubber roof for any length of time? I pretty much know what to expect with he roll roofing - factory or better (probably better because we would do what the factory neglected to.
But the liquid rubber although is sounds great, I would love to hear from people who have done it. how has it held up? Is it really maintenance free?
thanks all - any suggestions would be much appreciated. BTW I am in Miami - hot hot hot. If anyone wants to help - just come on by!
  • where is it $100 per ft in FL? Prices I was quoted were $3700 plus extra minimum ( i have only 261/2 of roof)
  • A new epdm rv rubber roof in Florida is $100.00 a foot Not including carpentry(rot soft spots ect) and that comes with new plumbing vents kitchen base and cap new a/c gaskets then instead of lap sealant, self leveling caulking using a 4" fiber backed seam tape, you will get 20 years plus with a maintenance free roof.
  • Those prices don't sound right- that would be a valid price for materials and labor for the Liquid Roof, but way to low for the EPDM membrane. The parts and labor to install a new roof is considerable- removing everything from the roof, including edge molding, install new decking, cut holes in new decking, glue the membrane down, reinstall everything on the roof.
  • I did the Liquid Rubber Roof on an older 5th wheel about 9 years ago. Have since traded 5vers but talked to the person who still has my old one and he has had not problems.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
