MrWizard
Aug 27, 2018Moderator
these ar the specs for the battery i posted
SPECIFICATIONS: Dimensions: 5.94x2.55x3.74 in (151x65x95 mm). Weight: 2 lbs 14 oz (1.30 kg).
Capacity: 10 ampere hours.
Lifecycles: Up to 80% capacity for 2,000 cycles in recommended conditions. (Typical SLA has 400 cycles)
. Terminals: F2 terminals 0.25 in. wide (6.35mm)
Discharge: 15 A max continuous, 60 A max 2-second pulse. 9.2 V max discharge, 11 V max recommended discharge.
For longest lifetime recommended discharge rate 1-5 Amps. {three in parallel equal 15amps load and long life}
Charge: 10 A max, 14 V max recommended, 15 V max. Compatible with most SLA chargers.
Operating temperature: Min:-20 F (-29 C) Max:120 F (49 C) . Max recommended environmental operating much better than SLA or other lithium s.
Includes active BMS protection circuit for increased performance and longer life.
SKU:ADIB00JK06CK8
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
