CA_Traveler
Mar 12, 2022Explorer III
Also 13.2V would not be a issue for me as it indicates a charged battery and the alternator is only supplying chassis and converter loads. A higher voltage indicates the chassis battery is drawing amps so at least the DC-DC converter has less conversion losses. Normally the alternator has extra capacity. IF this causes a alternator issue then the installation etc was at fault and needs to be corrected.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
