theoldwizard1
Mar 12, 2022Explorer II
CA Traveler wrote:
Also 13.2V would not be a issue for me as it indicates a charged battery and the alternator is only supplying chassis and converter loads. A higher voltage indicates the chassis battery is drawing amps so at least the DC-DC converter has less conversion losses.
Almost all vehicles for the past 15-20 years or so, use some kind of a smart charging system. The voltage from the alternator is controlled by the engine computer and can vary over a wide range.
