CA_Traveler
Mar 13, 2022Explorer III
theoldwizard1 wrote:Does this apply to MH engines delivered w/o an alternator which is upgraded to a larger alternator due to the larger power demands? Is there any additional information on this subject?CA Traveler wrote:
Also 13.2V would not be a issue for me as it indicates a charged battery and the alternator is only supplying chassis and converter loads. A higher voltage indicates the chassis battery is drawing amps so at least the DC-DC converter has less conversion losses.
Almost all vehicles for the past 15-20 years or so, use some kind of a smart charging system. The voltage from the alternator is controlled by the engine computer and can vary over a wide range.
