S_Davis
Mar 13, 2022Explorer
theoldwizard1 wrote:CA Traveler wrote:
Also 13.2V would not be a issue for me as it indicates a charged battery and the alternator is only supplying chassis and converter loads. A higher voltage indicates the chassis battery is drawing amps so at least the DC-DC converter has less conversion losses.
Almost all vehicles for the past 15-20 years or so, use some kind of a smart charging system. The voltage from the alternator is controlled by the engine computer and can vary over a wide range.
Not on 2009, 2013, 2019 GM 2500HD diesels, my last three trucks all have had steady voltage at about 14.2 no matter what. They must be in the almost none category.
One of my Redarc 50 amp chargers pulls 50 amps from the alternator and output is about 46 amps to the batteries, so on Redarc it looks like the rating is what is pulled from the alternator.
