otrfun
Mar 19, 2022Explorer II
Tom/Barb wrote:Care to share all the voltage/current readings (battery/alternator, charger input, charger output, and battery terminals) for your Victron dc2dc charger install. Charger output current/voltage readings alone reveal very little.otrfun wrote:It's all on my iPad./phone. (Bluetooth)
Bottom line, if you don't know the voltage/current readings at all your critical I/O points, then you haven't accomplished the minimum due diligence necessary to determine whether your system is truly operating as designed or not.
