greenno
Mar 12, 2023Explorer
You should be able to use a microwave for short periods of time as well as a coffee maker if you choose.
It sounds like you already have some solar to replenish your bank so as long as it's somewhat sunny your good to go.
You didn't state it but Im sure you know you need an Inverter for the 120vac devices correct?
We have a bit more capacity at 560ahrs and I installed a 3kw Inverter for our AC loads when we need them.
Got 510w of solar on the roof as well so that pretty much tops us off when we do use the Inverter.
Good luck.
Good luck.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
