wa8yxm
Mar 12, 2023Explorer III
Some numbers to consider.. MY JEEP
I have about 10 feet of #10 (10ga) ZIP cord between the battery (73AH Lead Acid) and the Rig Runner 5-40 (This is a power distribution box. 5 pair or anderson Power poles and fuses. the biggest one is fused at 40 amp. all pairs are rated 40 but may be fused smaller.
From there I use the stock factory 12 volt cable terminated in 40a amp andersons to my Kenwood TS-2000.. at 100 watts transmit power (About 20 amp draw) The radio shuts down due to low voltage.
Option 2 is a 12 AH LiFePO4 that's right 12 AH... I have a very short (like 6" or less) of 12 Ga wire and a pair or 40 Amp Andersons (We hams tend to use a lot of Andersons. I've a 40-12 Rig Runner behind me as I type. about half populate)
Full 100 Watts. NO voltage sag Im drawing nearly twice as many amps as the amp hour rating.
Your microwave may draw around 100 amps (100-120) or 1/2 the battery bank amp hour rating... I suspect it will work.. likel for around 1.5 Hours on a full charge.
