StirCrazy
Mar 13, 2023Moderator
12thgenusa wrote:
I’ll make my question a bit clearer.
When I designed and installed my system 12 years ago, lithium was still a dream for RVs. The battery discussions revolved around whether it was best to use a 12-volt battery or multiples of them, 6-volt batteries in series, or break the bank and go with AGM.
At the time, most agreed that a pair of GC2s in series were marginal to operate a microwave. That convinced me to go with four GC2s (440 Ah).
My specific question is, are the characteristics of lithium batteries sufficiently different from FLAs that 200 Amp hours of lithium batteries with at least a 200 amp BMS will operate the microwave without voltage sag causing inverter under-volt alarm or shutdown?
Should be, is not a helpful answer.
if you had a 200A BMS in one battery it would operate a microwave nice. two no problem.. the advantage of LFP is there is alomost no voltage sag undel load (there is but it is small) that is why you needed 4 GC instead of 2 as with only two the voltage sag when they get to about 80% of capacity will start your alarm going on the inverter. the LFP will stay above the alarm voltage untill they are down around 5ish % capacity.
