Almot
Mar 22, 2021Explorer III
It is not uncommon for LFP manufacturers to make battery with BMS cut-off very low, so usable charge of, say, 100AH battery is 97-99AH. Doesn't mean you should draw 99AH every time, it will last longer if you stop at 20%. But then, it will last longer yet if you stop at 40 or 50%. They are not different from wet cells in this respect, the shallower is cycle - the longer is life, but LFP are much more tolerable to partial charging than wet cells (with due consideration to cells balancing).
Some manufacturers make ~120AH battery and sell it as 100AH, with BMS cut-off at ~15% so you are getting 100AH without much damage to cycle life. Lynax were mentioned in another thread. They rate some of their batteries this way (not all of them), and call it "true"-something. You run nominal 100AH battery all the way to BMS cut-off and get 100AH with inaccessible 20AH remaining.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
